End Of Part (EOP) Stop Block Or Pin Idea
Greetings:
This is more of a design idea question or brainstorming. This is a just an attempt if someone has a good idea that is able to share, if not, I understand. I'm looking for an EOP stop (check) block or swivel pin idea to work with my fixture. I attached a snapshot of the idea that I've started with so far. If anyone has any better, simpler ideas that might be less bulky, I would greatly appreciate your feedback.
Thank you in advance,
RE: End Of Part (EOP) Stop Block Or Pin Idea
I don't see what the green piece is doing. Nor the tooling ball.
If you're looking to locate the red part 'axially' (so to speak) then yea, any hard object for it to contact will suffice. If it must be removed after clamping the part in place, then just make it a pin that slips into a bushed hole or something like that. I've used 1" dia stepped pins in a bushed hole as a stop for something to repeat, but still needing cutting tools to access the feature I'm locating off of. Slip pin into bushing. Slide part against pin. Clamp part. Remove pin.
For future reference, see: http://www.eng-tips.com/threadminder.cfm?pid=281
