Looking for a publication.
I'm looking at the product data bulletin for 17-7PH steel from AK steel located here:
http://www.aksteel.com/pdf/markets_products/stainl...
I'm looking for information about welding and required post weld heat treatment and in the weldability section it ends with this line:
More information can be obtained in the
following way:
“Welding Stainless Steels,” FDB #SF-71.
I'm not finding this online or even what publication this is. Could someone point me to a source? Also, recommended post weld heat treatment for .050" thick sheet that has a crack that needs to be welded?
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: Looking for a publication.
Call AK and ask..
Re: Also, recommended post weld heat treatment for .050" thick sheet that has a crack that needs to be welded?
First, what is the heat treatment condition of the 17-7PH material??
TH1050 is the current condition.
-Kirby
Kirby Wilkerson
You will need to most likely perform a reheat treatment after welding using 17-7PH wire with the GTAW process.
Follow the AK Steel recommendation for heat treatment and age hardening. After welding heat to 1400 deg F to get to Condition T - austenite. Age harden at 1050 deg F to establish the T1050 in the weld region and sheet material.
You can look at trying to subject the weld region to the 1050 deg F aging treatment after welding but I think this will reduce the strength properties of the bulk sheet material.
Thank you. I indicated to heat treat to condition TH1050. I saw a paper about 17-4PH that indicated good strength going straight to the ageing treatment for H1150 after welding, but I wasn't sure if a similar process would have equivalent results for this material.
-Kirby
Kirby Wilkerson
Despite both alloys being precipitation hardening, they respond differently. 17-7PH is not as weldable as 17-4PH.
I can send you the 17-7 handbook that covers everything.
If it is TH1050 and the properties matter than you would want to anneal it, weld, maybe re-anneal, austenite condition, and then age.
This alloy is austenitic when annealed and it welds very well.
Let me know how to send the file to you.
If you could email it to kwilkerson_at_goverticalaero_dot_com I would appreciate it.
Thanks all!
-Kirby
Kirby Wilkerson
