Hot and Cold Insulation Thickness
thread391-262608: Insulation thickness/surface temperature
Dear All,
I was reading the topic thread391-262608: Insulation thickness/surface temperature and Mr. AllHandlesTaken and Mr.Ione indicated two free software to thickness insulation calculation.
- http://www.pipeinsulation.org/ (3EPlus)
- http://www.kaicalc.de/ (company)
Has anyone tried these programs or other programs ?
Has anyone positive or negative comments about these programs or other ?
Best,
Biava
Dear All,
Best,
Biava
RE: Hot and Cold Insulation Thickness
It is the only one I have used, so I don't know how it compares with others.
It does allow for user addition of other pipe and insulation materials.
The only downside is it forces you to use NPS, so you cannot use pipe materials that have other wall thicknesses.
http://insulationinstitute.org/tools-resources/fre...
Thank you for your comment. What insulation system type have you used the 3EPlus ?
With Regards
Only fiberglass and elastomeric pipe insulation.
