Help with fan test setup
So I am hoping this is the right forum to post this in but i have a question regarding the set up for a test series I want to conduct on a number of different fan models.
I am interested in conducting acoustic testing for a number of different fan models at a constant cfm rate and at different sp (inH2O) values in order to find a maximum acoustic signature at each data point.
For example: I want to test a fan at 250 cfm and then scale the SP rise from say 2.0" to 3.5" (by 0.1" increments) using an airflow damper upstream of the fan as well as varying the fan speed in order to find the noise level at each SP value.
My question is: Is there a way to analytically determine the SP stall value for the fan at a given cfm before testing so that I can narrow the range of values of SP i am testing in? I have the fan curve provided by the manufacturer but I am not sure how to best utilize it for this scenario and i would like to justify the results to myself as well.
Thanks in advance for any help!
RE: Help with fan test setup
The file in the attachment can give you further insights
