Sending out RFQ 2D Drawings v 3D Models
Is there anyone here that doesn’t actually send out 2D drawings, just 3D models when getting RFQs? I’m quite ignorant of the the differences but I suppose logic tells me that people are more used to 2D, they are probably a bit more personal with more info than a 3D model plus the receiver has more checking to do on a 3D model hence more time for them.
Are there any advantages for the receiver/manufacturer to receiving 3D models and some ways to make the model more receiver friendly? As far as I remember dimensions can be made visible in a 3D CAD model and when it's just for quotation purposes manufacturers would just need the critical dimensions/tolerances to decide what price to charge?
I’m asking as I’m doing some research as part of an Agile thesis I’m working on and am mapping out the design process, drawings take up a lot of time and things can get messy when revisions are made and hard copies are floating around etc etc.
RE: Sending out RFQ 2D Drawings v 3D Models
When you send out a purchase order to Billy Bob and Cousin Elmo's machine shop, you need to provide clear instructions. Think of the PO as a contract. Think of your part info, 2D drawings, 3D models, scribblings on napkins, etc., as clauses in your contract.
This is less critical at the RFQ stage, but, however much Billy Bob and Cousin Elmo love fabricating stuff, they need to make money. They will learn whatever it takes to not under-quote. When they mess up stuff you did not specify clearly and accurately, they will do the re-work for free, and they will build this effort, along with the time they spent on the phone asking questions, into their next quote. The quality of your information will affect quality and cost.
2D drawings can be prepared to a well-documented standard like ASME Y14.5. I claim that the clear definition of what everything means actually is more important than the GD&T. If your 3D model is sufficient to define your part and provide clear accept/reject criteria, send them the 3D model. This is not the same thing as sending a complete 2D drawing, then sending them a DXF or 3D model when they ask for it. In this case, the drawing is the legal reference.
JHG
There are services that will machine/mold/3D print just to the model but essentially only say they'll keep to their typical process capability regarding tolerance. By implication these places also quote to just the model. We use these services for prototypes and the occasional 'one off' or very low volume production part that don't have any finish requirements etc.
For MBD to work the information on things like tolerances, and what would normally be in notes or title block (e.g. material, surface finish...) need to be included in the model and accessible to the user.
So, much of the time saved on 'drawing creation' will now be spent in annotating the model more thoroughly - and revision of the model still needs to be controlled etc.
Things may have improved but not long ago when I last looked this was only really possible in fairly integrated supply chains where the people creating the MBD were if not on the same CAD system as the users at least in a position to coerce them into getting viewers etc.
Y14.41 is the relevant ASME standard.
We routinely send 'dumb' models of parts (as reference) along with the drawings to help shops program CAM etc. They may use this to help them estimate, not sure.
Another point is a lot of machine shops don't seem to do a very good job reviewing the drawings etc. when quoting - and this is when it's all laid out in front of them in an easy to read format. Once they are working in a model having to retrieve saved views and various things my guess is they're even more likely to hit snags when they actually take the order.
However, maybe I'm a luddite trying to protect his job.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
MBD (as it's done today) is not the answer.
If it's a simple project: a good PDF drawing with all the views and requirements will work.
A complicated project: a good PDF drawing and the models. The customer should inquire about your CAD, otherwise IGES or STEP.
Harold G. Morgan
CATIA, QA, CNC & CMM Programmer
I had done a search and looked at the first 3-4 results but din't know the MBD acronym was relevant.
"When its just for quotation purposes" - if I were a machine shop, I would routinely no-quote RFQs based on nothing more than a model, as such jobs are likely not going to gel soon, and will not reach economical quantities for awhile - thus are time wasters for people who want to make money.
"...drawings take up a lot of time and things can get messy when revisions are made and hard copies are floating around etc etc."
Maybe taking a little more time to finish a drawing will help the design get a bit more refined and a bit closer to reality. Revisions are a problem with model files as well, and without a system to track/control changes, things can get equally messy.
PMI (Product and Manufacturing Information) is another acronym that may turn up some relevant information.
"Maybe taking a little more time to finish a drawing will help the design get a bit more refined and a bit closer to reality". This wasn't likely to happen in the setup I was in last. The designer just hands parts over for detailed drawing when he/she is done with the design. i goes trust and collaboration has a big part to play. I guess not all manufacturers have the software however to be able to view files.
I do my own fabrication drawings, and it does not take very long. Since I am the designer, I know how the part must work, so I know what tolerances must be applied. In 3D, I slap on dimensions and I slap on tolerances. The only time things get difficult is when my tolerance stack-ups do not work, but this is a design issue, not a drafting issue. It is best not managed by a CAD monkey.
JHG
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
A good way to communicated design intent is via a properly prepared drawing...
An old/wise fastener engineer in the company I work for stated this elegantly as follows: "You deserve to get what you ask for: but if You don’t ask for very much, don’t-expect to get very much.” Every part has details not shown on the drawing. Raw material, heat treatment, fab processes, machined surface finishes, general tolerances and machined-miss-match allowances, DI, NDI, corrosion protective finishes, etc/etc. ALL of these details must be carefully thought-out and evaluated in-sequence of manufacturing; and clearly/concisely [non-ambiguously] added to the drawing and/or contracting data.
EXAMPLE
I am currently evaluating a machined-magnesium casting design for local manufacture [machined 'hogout'] from aluminum plate. The M&P side is relatively easy: Yes 7050-T7451 plate 5--8-inches thick is a suitable substitute material [with corrosion protective finishes for aluminum]. HOWEVER, it is NOT rocket science to understand why this part was a casting: very complex/acute/internal geometry that might be impossible [or not-cost effective] to machine. We will need to consult with the guys who will be 'tasked' to machine it... then decide how to proceed. A 3D model for complex NC machining will probably be required. However, This part might be better/best suited for low volume [steriolithography 3D-printing] of the wax model for a lost-wax aluminum sand-casting.
NOTE. Venting...
What really bothers me is when a simple machined part on a clear 2D drawing cannot be machined by a competent machinist... since most machinists are no-longer capable of 'hand machining' operations: it's a programmed NC machine-job, or nothing.
Regards, Wil Taylor
o Trust - But Verify!
