Problem: Empty Hole table in NX 11.0
Dear all,
I have a problem with creating Hole Table in NX 11.0, when I click on Hole Table then select origin and when I select objects (holes) I dont get coordinates in table, Hole Table is empty. But in drawings where I have Hole table I can create table again (after deleting existing one).
RE: Problem: Empty Hole table in NX 11.0
Quote (Siemens Gtac)
Siemens PLM believes that the problem you reported where Holetable is not working will be resolved by code changes made to the release of our productNX11.0.2.
Fix is versioned. Version up pre-NX11.0.2 hole table or create new hole table.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Hole table is working but there seems to be a bug in the code, because I used the same part where I couldn´t make hole table and make a base view from his GEO and then I can create hole table from that part. I am working parts in the form like PART_NAME.prt and that is assembly that contains my part with name PART_NAME_GEO.prt. I cant create hole table when I make base view from PART_NAME.prt but from PART_NAME_GEO.prt I can. And other solution is to use a drawing from other part where hole table is created and just replace part and do the update and recreate hole table. This two Solutions prove that Hole Table is working but not like it used to work before.
