Rigid Insulation vs EPS Foam - Weights of Materials
The weights of material table in the steel manual and the minimum design dead loads table in ASCE-7 lists rigid insulation at 1.5 psf per 1" of thickness. Does anybody know what type of rigid insulation this is? It's heavy. EPS foam is typically around 1 psf per 12" of thickness (1 pcf). Thanks!
RE: Rigid Insulation vs EPS Foam - Weights of Materials
