Concrete Cure Room Shelving
My lab has a cure room with older shelving. We are running out of space for the number of samples we get, and I'm thinking of building new shelves to optimize the space in the room. The shelves are older, and no one who currently works here knows who built them. They are fairly rugged as well, and have 4 shelves each which we use for sorting samples by date. There is some empty space in the corners, which if we design new shelving we could use, and not have to install a separate tank elsewhere.
Does anyone have experience building shelving for concrete cure rooms? What is the best material? Our old ones are wood, presumably with some sealant to keep them from rotting. What would be the best sealant if we make new ones from wood again? Any other things to keep in mind with the damp conditions in the cure room? I'm hoping to make similar shelves to what we have, just slightly taller and using the dead space in the corners, but I don't want to build something that will rot or fall apart quickly.
Thanks so much for any ideas!
RE: Concrete Cure Room Shelving
Thanks so much for the input on stainless steel for material, I'll look into it! :)
