Ya know SAP2000, after the design p
Ya know SAP2000, after the design process, outputs the beam reinforcemnt at three locations: left, middle and right along the beam length. I need to change some of the computed reinforcement as per the design code I am following. Anybody can help me do that? I tried to use the ovewrites, but I guess the overwrites are not for that purpose. Thank you in advance.
RE: Ya know SAP2000, after the design p
You may do that by refining the design parameter before running dessing, since CSI account for reinforcement from analysis load cases. ALternatively change your sectional proeprties/materials to have different reinforcement layout.
Shoot for the Moon, even if U miss, U still land among Stars!
Thanks for the response and suggestion.
You can modify the sectional properties and specifically using the reinforcement parameters form.
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Interaction Diagrams
Reinforcement Design etc.
