Repair of Crude Column without Shutdown
Is it possible to make an extra layer of material on the corroded section of a pressure vessel to delay the shutdown?
RE: Repair of Crude Column without Shutdown
I recall two instances of weld repairs to Crude columns in service that led to catastrophe. Do be extraordinarily careful!
This will be one of the first questions asked by the authorities if things go wrong ....
Where is the location of this column ? Inside the United States ????
MJCronin
Sr. Process Engineer
As I am not specialized in pressure vessel design so should study it based on your comments and come back.
Still I will try to gather information and share with you, if I get any.
Welded Encapsulations are one of many topics addressed in ASME PCC-2 Repair of Pressure Equipment and Piping Part 2. They're used commonly enough, and easy to fabricate out of materials readily available at most refineries and upstream facilities. Nothing secret or special about them, but it does help to have a pretty thorough understanding of vessel design, and occasionally, design by analysis.
