Interaction Contact in Abaqus
I am trying to research a modele in Abaqus by thermal and mechanical analysis. The module has several contact points. Firstly, I thought about defining contact points through „Tie Contact“. The program ran quite well. After I got results, I wanted to replace „Tie Contact“ with „Interaction Contact“. Unfortunately after a few minutes the program breaks by an error message "Displacement increment for contact is too big". I have already tried to change the geometry at the contact points and vary Increment Size without any success (I would be very happy for some help). Tank you in advance
