Is the number of stage constant? When the components in the system change?
Hi everyone,
If I find the number of stage for the test run for Benzene Toluene unit
and I find that the number of equilibrium stage should be 50 stages.
If I turn the system into the extractive distillation.
To separate Benzene and other non-aromatic components by using the solvent, NFM.
Shall the number of stage in this case be 50?
Thank you for your answer.
RE: Is the number of stage constant? When the components in the system change?
