Minimum Reinforcement in Shallow Footings (Beam or Slab?)
We've recently opened up discussion in our office about minimum reinforcement requirements in shallow footings.
ACI318-11 13.3.2.1 states that the design, detailing of one-way shallow foundations, including strip footings, combined footings, and grade beams, shall be in accordance with this section and the applicable provisions of Chapter 7 and Chapter 9.
Chapter 7 "One Way Slabs" states that minimum reinforcement shall be: 0.0018x60000xAg/fy or 0.0014Ag
Chapter 9 "Beams" states that minimum reinforcement shall be: 3xsqrt(f'c)xBwxD/fy or 200xBwxD/fy
I've normally followed 0.0018Ag as my minimum guideline but as per Chapter 9, my minimum is greater.
RE: Minimum Reinforcement in Shallow Footings (Beam or Slab?)
Dik
Dik
In 318-11 the provisions for footings are in 10.5.4 as EngineerEIT indicates above....and are very very confusing to some - see this thread: thread507-251751: How to place minimum steel in a rectangular footing?
However, it appears that 318-14 has cleared up this mess from 10.5.4.
One thought I have on this is that it may be that this section, 13.3.2.1, refers to footings and then to "grade beams" and that the chapter 7 provisions are for general one-way footings while the chapter 9 provisions are for grade beams. That to me is rational.
Having said that I would possibly concur with you that the higher of 7 vs. 9 would be prudent.
But it does say "as applicable" when mentioning 7 and 9 in 13.3.2.1. which implies that 7 applies to some and 9 applies to some.
You're absolutely right. It is 2014 not 2011. I think I'm also onboard with Chapter 9 as my minimum.
The conversation came up as our min reinforcement has always been 5 @ 12 for a 12" thick footing under light loading. Now it is 6 @ 12.
