Pre-tensioning bolts in hardened epoxy?
Hi there,
If bolts are installed as snug tight before the epoxy is placed around the bolts, is it still possible to pre-tension the bolts (using turn of the nut method) after the epoxy is placed and has hardened (see sketch)? Or would the hardened epoxy completely prevent the bolts from turning a 1/2 turn?
RE: Pre-tensioning bolts in hardened epoxy?
@MotorCity Thanks for the advice, shims are used along with the epoxy.
