How heavy should a boat mooring be ?
Hi all
It's way beyond me to figure a way of calculating the weight of the block that I should drop to secure the boat to or even an estimate. I was just hoping someone may be able to help.
The boat = 50' catamaran, small windage possibly 35m^2 sideways and 18m^2 head on.
Weight = 8t
The mooring will be approx. 7300kg/m^2
Sea floor = sand
Depth = 6m to 8m
Line from weight to buoy length = 24m
Expected max wind = 60kn / 111klm / 69mph
Anyone care to have a go ?
Dave
Weight = 8t
Sea floor = sand
Depth = 6m to 8m
Dave
RE: How heavy should a boat mooring be ?
With sand you might enjoy the mooring sinking into the sand, forming a bit of suction. That would be beneficial.
In any case I think you'll need a sensible way to account for this. Perhaps someone with maritime experience can answer.
Mike McCann, PE, SE (WA)
Hope you were on about the naval aircraft carrier USS Enterprise rather than Starship USS Enterprise, serial number NCC-1701, of the United Federation of Planets as I have never seen the later in water!!!
I just checked Chapmans I have copies of the 52nd and 53rd editions , Their recommendation is a star mooring with three mushroom anchors, there is also a size and rope diameter table there . This occurs on pages 114 and 115 of the 52nd edition.
B.E.
You are judged not by what you know, but by what you can do.
I have talked to a number of companies that drop moorings and have had 4 replies. 800kg, 1400kg, 2000kg, and 5000kg and breaking strain line from weight to buoy of 12000kg to 30000kg.
It has to be rope for Eco reasons to stop the surrounding damage to sea grass. I take your point on the chain and will run a metre of chain so it can't damage the grass and hopefully reduces the chafing on the rope.
The weight is made from old worn out train wheels so I do expect them to settle in the sand to an extent.
Chapmans ?
Can't use an anchor in a storm over 30kn for insurance.
Dave
I just have the printed books here, the book is published by Hearst corp you could do a Google search.
B.E.
Amazon has some copies new and used starting at around $30.00 .
B.E.
Cheers
Greg Locock
I'm going there this weekend so I'll dive on others and see what they have, they are rentals though and for much smaller boats in calm weather only.
Thanks boo1 and all.
Dave
Cheers
Greg Locock
I was thinking's of a rope with lots of stretch like nylon, but not nylon.
so you're going to use a large float to suspend your anchor line so that it doesn't touch the blessed grass. how do you show that the line doesn't touch in the lowest trough and highest wind ?
He is in an area that has eelgrass conservation laws/rules. chains dragging around on the bottom destroy the eelgrass.
This is where the triple block anchors work better because the chains don't move around.
B.E.
or do you meant three anchors (so the boat doesn't move) ?
No, a permanent mooring is made by putting 3 anchors ( Or blocks.) on the seafloor in a equilateral triangle with the anchor chains going to the centre of the triangle, at this point a swivel is attached, then a Nylon rope goes up to the boat at a length for the correct scope, as the boat moves around, the 3 anchors take the load one at a time according to the wind/tide/current. The chains only lift up and down with the load, and only disturb a small section of the seabed ,
this is the preferred method in an eelgrass sensitive area , compared to a single chain from a mooring which will sweep around in a circle on the seabed tearing up anything in its path.
B.E.
there's a world of difference between "none" and "some". there'd be some slack in the rope, hence some drag on the grass ... I was picturing buoys to hold the cable off the sea floor. and the blocks are permanent
I didn't think you'd want 3 different anchor points
