NX9- Drilled holes on assembly
Hi , I'm wanting to show drilled holes in two components that are screwed together and then dowelled into position on assembly. (the items are screwed together and then both items are drilled and dowelled)
I know how to use the assembly cut function but this leaves me with a flat bottom, I want to show the drill point on my drawings.
I have tried insert/ design feature / hole but I cannot get it to work on an assembly.
Any ideas?
Any ideas?
RE: NX9- Drilled holes on assembly
It's specifically for doing just that.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
