Need justification to eliminate salt spray testing of 300 stainless parts
I have a customer who makes marine accessories and uses a number of 304 stainless steel screws. They call out a 500 hour salt spray test for these screws. We get random salt spray failures even after passivation. I am trying to get the customer engineers to understand that this is not a valid test for these screws. Does anyone know of a document or source that specifically states that the B117 test should not be used for stainless steel parts?
By the way; I have tried to get them to change to 316L and they won't consider it because of the "prohibitive" cost.
I am almost to the point of recommending that we tell them that we will no longer supply these parts because of this salt spray test that they are putting the parts through.
RE: Need justification to eliminate salt spray testing of 300 stainless parts
That is the kind of info that I was looking for. I knew that I had seen the 2 hour requirement that is in QQ-P-35, but I couldn't for the life of me remember where it came from.
As far as I know, there is no actual scientific basis for the spec, it is something that someone at the customer "developed". This organization also tried to tell us that they had developed an "accelerated" test method that could determine if parts would pass the 500 hour test. The accelerated method consisted of wrapping copper wire around the parts to be tested, putting them into the SS chamber and then running current through the wire! When asked what the specification was for this, they were dumbfounded that we would ask such a thing.
Charge accordingly for time, equipment etc. You need to make a profit on the 500 hour testing also.
If you are making a profit when you ship the parts, why fight it?
304 will not stand up to seawater, even just spray.
And in a fastener application where there are tight crevices 316 will not survive long either.
316 only works in marine hardware where it can be washed off with fresh water regularly.
They are conducting the test in-house on received parts. All we are getting out of it is returns on parts that are failing their test.
Ed,
These are lightly loaded AB tapping screws that are holding auxiliary electronics in the cockpit area. If it was any type of structural components I would be running too.
The 5 hour maximum test makes sense if you are looking for anodic surface contamination. However, it is insufficient for general corrosion identification from exposure. That is a customer-specified property. In recent memory, our lab has conducted such testing for 300-series coupons for up to 200 hours of exposure.
There are actually much more sensitive tests for Fe contamination.
My favorite is to use white Head and Shoulders shampoo. The active ingredient will complex with Fe and turn blue.
A thin layer of H&S, misting with DI water to keep damp, and a few hours. The most sensitive test that I have ever used.
