UI Block Styler - Specify Point
Dear Forum,
I am creating a UI Block styler for the creation of associated points within a component or within an assembly. The specify point control work great for creating a point within a component. But doesn't allow the selection of edges or any of the point constructor features within the assembly. I am missing a setting when creating this control in UI Block Styler??
RE: UI Block Styler - Specify Point
Hi
You can change the selection filter scope to "Entire Assembly" when you want to select a point.
