Breakaway Torque Formula For All Valves
hello
I am looking for formula to calculate required torque for following valve:
Gate
Glob
Ball (Float and Trunnion)
Or, is there any reference for selecting manual gearbox for valves?
thank you
RE: Breakaway Torque Formula For All Valves
Generally how much torque a valve needs for its operation?
consult the manufacturers literature, the valve has to be made to accept the actuator.
mmbguide,
If you are working as a mechanical engineer for a valve company which does not have the engineering capabilities in terms of hardware, software and HR, you may need to take a different approach to this.
In almost all cases, the torque to be developed is when the diff pressure across the valve is equal to the larger of the process design pressures on either side of the valve.
There should be common forum from manufacturer engineering, but it's little difference based on diff design and different factor added, so you would better confirm to your suppler.
