What elements to publish / "virtual axis" publication
Good morning,
You can find below two screenshots of what I am trying to do:
Is there any way I can publish the "virtual axis" that you usually use to make coincidence constraint ? So far I can publish a real axis (line) and use this to make coincident constraints, but i find this to cumbersome for really fast usage.
What exactly i have to publish in a part to not brake the fix constraint when i replace that part in an assembly.I tried publishing the PartBody and the axis system, but it seems they don't work.
Best regards,
Costin Ruja
Best regards,
Costin Ruja
Best regards,
Costin Ruja
RE: What elements to publish / "virtual axis" publication
Best regards,
Costin Ruja
