Set dashed line in drawing vba catia
I can not find how to adjust dashed line in drafting for catia. Below is some code for Linetype, but result is still filled line.
How to define a thin dashed line in vba code?
Set Line11 = Fact.CreateLine(22.5, 9.25, 192.5, 9.25)
Line11.Name = "Line11"
CATIA.ActiveDocument.Selection.Add Line11
Set visProperties1 = CATIA.ActiveDocument.Selection.VisProperties
visProperties1.SetRealLineType 4, 0.2
visProperties1.SetRealWidth 2, 0.2
Thank you for any suggestions,
RE: Set dashed line in drawing vba catia
Can you try on a test drawing this?
CODE --> CATScript
Language="VBSCRIPT"
Sub CATMain()
Dim drawingDocument1 As Document
Set drawingDocument1 = CATIA.ActiveDocument
'-------------- select generated items
Dim selection4 As Selection
Set selection4 = drawingDocument1.Selection
selection4.Search "CATDrwSearch.CATEarlyGenItem,all"
visProperties1.SetRealLineType 1,0.2 '-----------change line type
visProperties1.SetRealWidth 1,0.2 '-----------change width
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
