TORSIONAL EFFECT IN SECOND MODE
Hello guys !!!
I have modeled and analysed a single story RCC building in ETABS and I found that the building have torsional effect in second mode. Is there any remedial measure to counter this effect in designing phase or in construction phase ?
RE: TORSIONAL EFFECT IN SECOND MODE
Manipulate your lateral load resisting elements such that your centre of stiffness is in the centre of your building. This will minimise load eccentricities that exacerbate torsional problems.
Make it hard for the building to twist, distribute lateral elements towards the perimeter of the building.
Yes. Relocate lateral load resistance elements in plan therefor reduce the distance between the center of lateral stiffness and center of the structure mass in plan.
What's the mass participation in the 2nd mode? If it's very low, that may be okay.
Also, I'd say it is as important to increase the torsional STIFFNESS of the system as it is to have that center of stiffness match up with the center of mass. Meaning if your lateral frames are wider apart then your torsional modes should be at a higher frequency.
Thank you for your kind response...
Dear JoshPlum, mass participation in second mode is 20%, I think it is quite appropriate. I am planing to provide shear wall of some length around the outer far end columns, so that it can help to reduce the torsional effect.
