mixing time calculations of jet mixers
hello
how can you calculate the time mixing of 250 m3 storage tank with a high viscosity liquid (350 cp)using the jet mixer?
Good luck,
mohsen
Good luck,
mohsen
RE: mixing time calculations of jet mixers
Ashtree
"Any water can be made potable if you filter it through enough money"
flow rate is 60 m3/hr
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Good luck,
Latexman
Good luck,
mohsen
Good luck,
Latexman
