Assembly Creation using a Text File
thread561-350926: Import assembly from excel/text file
Hi
i am using the same code to create a assembly file with sub-parts/sub assembly .The error i get attached below.
This returns NXOpen.NXExcelption :The selected template doesn't exixts.
I had even run your code for getting templetes for your earlier post and the code is below for getting templetes.
XXXX_startpart_model.prt
XXX_startpart_assembly_mm.prt
XXX_startpart_drawing.prt
XXX_startpart_drawing_standalone.prt
XXX_startpart_drawing_schematics.prt
YYY_startpart_drawing.prt
YY_startpart_drawing_standalone.prt
ZZZ_startpart_drawing.prt
ZZZ_startpart_drawing_standalone.prt
FemNxNastranMetric.fem
SimNxNastranMetric.sim
FemNxThermalFlowMetric.fem
SimNxThermalFlowMetric.sim
FemAbaqusMetric.fem
SimAbaqusMetric.sim
Blank
Blank
The Code for obtaining this is
Option Strict Off
Imports System
Imports NXOpen
Module Module1
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim lw As ListingWindow = theSession.ListingWindow
lw.Open()
Dim templates() As String
templates = theSession.Parts.FileNew.GetAvailableTemplates
For Each temp As String In templates
lw.WriteLine(temp)
Next
lw.Close()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
Could you please change my code for this particular template
The code i need that you need to change is,
'eng-tips thread561-350926: Import assembly from excel/text file
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.Assemblies
Module Module3
Dim displayPart As Part = theSession.Parts.Display
'folder that contains existing parts; new parts will be created here
'change the directory path as necessary
Const partFolder As String = "C:\Users\dinessu\Desktop\TA top gun\Assembly"
'string of characters that indicate the assembly structure in the text file
Const levelIndicator As String = "."
'main assembly.prt
'.first_sub.prt
'..comp1.prt
'..comp2.prt
'.second_sub.prt
'etc, etc.
Sub Main()
If Not My.Computer.FileSystem.DirectoryExists(partFolder) Then
MessageBox.Show("The specified folder, " & partFolder & ", does not exist..." & ControlChars.CrLf & _
"The journal will now exit.", "Folder does not exist", MessageBoxButtons.OK, MessageBoxIcon.Error)
Return
End If
lw.Open()
Dim asmTextFile As String = GetTextFile()
If asmTextFile Is Nothing Then
'user pressed cancel in the select file dialog
Return
End If
Dim textFileTree As NXTree(Of String) = TextFileToTree(asmTextFile)
Dim processedPRTFiles As New List(Of String)
ProcessTree(textFileTree.Root, processedPRTFiles)
lw.WriteLine("Done")
lw.Close()
End Sub
Sub ProcessTree(ByVal BOMTree As NXTreeNode(Of String), ByRef listFinished As List(Of String))
If listFinished.Contains(BOMTree.NodeObject) Then
'we've already processed this part, move along...
Return
End If
'part has not been processed
If My.Computer.FileSystem.FileExists(BOMTree.NodeObject) Then
'file exists, compare it to the BOM
Dim myAssembly As New NXTree(Of String)
Dim extraComps As NXTreeNode(Of String) = myAssembly.MakeRoot(BOMTree.NodeObject)
Dim myPart As Part
'create part list from actual CAD file
Try
myPart = GetPart(BOMTree.NodeObject)
Dim c As ComponentAssembly = myPart.ComponentAssembly
If Not IsNothing(c.RootComponent) Then
'*** insert code to process 'root component' (assembly file)
For Each child As Component In c.RootComponent.GetChildren()
If Not IsNothing(child.Prototype.OwningPart.FullPath) Then
extraComps.AddChild(child.Prototype.OwningPart.FullPath)
Else
lw.WriteLine("component not found: " & child.Name)
End If
Next
End If
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
'add missing components
For Each tempNode As NXTreeNode(Of String) In BOMTree.Children
ProcessTree(tempNode, listFinished)
Dim found As Boolean = False
For Each existingNode As NXTreeNode(Of String) In myAssembly.Root.Children
If existingNode.NodeObject = tempNode.NodeObject Then
found = True
For i As Integer = 1 To tempNode.Quantity - existingNode.Quantity
AddComponent(myPart, tempNode.NodeObject, Nothing, Nothing)
Next
End If
Next
If Not found Then
'add it
Next
End If
Next
Else
'file does not exist, create it and add components per BOM
Dim myNewFile As Part = GetPart(BOMTree.NodeObject)
For Each newComponent As NXTreeNode(Of String) In BOMTree.Children
ProcessTree(newComponent, listFinished)
For i As Integer = 1 To newComponent.Quantity
AddComponent(myNewFile, newComponent.NodeObject, "", Nothing)
Next
Next
End If
listFinished.Add(BOMTree.NodeObject)
End Sub
#Region "text file to assembly tree functions"
Function GetTextFile() As String
Dim openFileDialog1 As New OpenFileDialog()
openFileDialog1.Filter = "txt files (*.txt)|*.txt|All files (*.*)|*.*"
openFileDialog1.FilterIndex = 1
openFileDialog1.RestoreDirectory = True
If openFileDialog1.ShowDialog() = DialogResult.OK Then
Return openFileDialog1.FileName
Else
Return Nothing
End If
End Function
Function TextFileToTree(ByVal textFile As String) As NXTree(Of String)
Dim separators(0) As String
separators(0) = ControlChars.CrLf
Using sr As StreamReader = New StreamReader(textFile)
Try
Dim asmStructure() As String
asmStructure = sr.ReadToEnd.Split(separators, StringSplitOptions.RemoveEmptyEntries)
Dim newPart As String = IO.Path.Combine(partFolder, asmStructure(0))
Dim root As NXTreeNode(Of String) = myAssembly.MakeRoot(newPart)
AddChildren(root, asmStructure, 0, levelIndicator)
Return myAssembly
Catch E As Exception
MessageBox.Show(E.Message, "Error")
Return Nothing
End Try
End Using
End Function
Function CountIndent(ByVal myString As String, ByVal indentChar As String) As Integer
If myString.Substring(0, indentChar.Length) = indentChar Then
Return CountIndent(myString.Substring(indentChar.Length, myString.Length - indentChar.Length), indentChar) + 1
Else
Return 0
End If
End Function
Sub AddChildren(ByVal assemNode As NXTreeNode(Of String), ByVal asmStructure() As String, ByVal item As Integer, ByVal levelIndicator As String)
Dim j As Integer = 0
Dim iLevel As Integer = 0
Dim jLevel As Integer = 0
Dim childPart As String
iLevel = CountIndent(asmStructure(item), levelIndicator)
'Dim prtI As String = asmStructure(item).Substring(iLevel * levelIndicator.Length, asmStructure(item).Length - iLevel * levelIndicator.Length)
Dim prtJ As String
For j = item + 1 To UBound(asmStructure)
jLevel = CountIndent(asmStructure(j), levelIndicator)
If jLevel <= iLevel Then
Return
ElseIf jLevel = iLevel + 1 Then
prtJ = asmStructure(j).Substring(jLevel * levelIndicator.Length, asmStructure(j).Length - jLevel * levelIndicator.Length)
childPart = IO.Path.Combine(partFolder, prtJ)
'Dim child1 As TreeNode(Of Person) = root.AddChild(New Person("First Level Node 1"))
Dim child1 As NXTreeNode(Of String) = assemNode.AddChild(childPart)
'add component as child
AddChildren(child1, asmStructure, j, levelIndicator)
End If
Next
End Sub
#End Region
#Region "File functions"
Function GetPart(ByVal partPath As String) As Part
Try
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Change Display Part")
Dim part1 As Part = CType(theSession.Parts.FindObject(IO.Path.GetFileNameWithoutExtension(partPath)), Part)
Dim partLoadStatus1 As PartLoadStatus
Dim status1 As PartCollection.SdpsStatus
status1 = theSession.Parts.SetDisplay(part1, False, False, partLoadStatus1)
workPart = theSession.Parts.Work
displayPart = theSession.Parts.Display
partLoadStatus1.Dispose()
theSession.DeleteUndoMark(markId1, "Change Display Part")
Return part1
Catch ex As NXException
If ex.ErrorCode = 3520016 Then
'part wasn't found in session
If My.Computer.FileSystem.FileExists(partPath) Then
'open part
Try
Return OpenPart(partPath)
Catch ex2 As Exception
MessageBox.Show(ex2.Message, "Error opening part", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Else
'part file does not exist
Return NewFile(partPath)
End If
End If
End Try
Return Nothing
End Function
Function NewFile(ByVal filePath As String) As Part
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "new file")
Dim fileNew1 As FileNew
fileNew1 = theSession.Parts.FileNew()
'change template as necessary
fileNew1.TemplateFileName = "model-plain-1-inch-template.prt"
fileNew1.Application = FileNewApplication.Modeling
'change part units as necessary (Inches, Millimeters)
fileNew1.Units = Part.Units.Inches
fileNew1.NewFileName = filePath
fileNew1.MasterFileName = ""
fileNew1.UseBlankTemplate = False
fileNew1.MakeDisplayedPart = True
Dim nXObject1 As NXObject
nXObject1 = fileNew1.Commit()
fileNew1.Destroy()
Dim markId5 As Session.UndoMarkId
markId5 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Name Parts")
workPart.AssignPermanentName(filePath)
theSession.DeleteUndoMark(markId5, Nothing)
Dim partSaveStatus1 As PartSaveStatus
partSaveStatus1 = workPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
partSaveStatus1.Dispose()
lw.WriteLine("New file created: " & filePath)
Return nXObject1
End Function
Function OpenPart(ByVal myPart As String) As Part
Dim thePart As Part
Try
thePart = theSession.Parts.OpenDisplay(myPart, partLoadStatus1)
Return thePart
MsgBox(ex.ErrorCode & ": " & ex.Message, vbCritical + vbOKOnly, "OpenPart error")
Return Nothing
End Try
End Function
Sub AddComponent(ByVal parentPart As Part, ByVal compPath As String, ByVal refSet As String, Optional ByVal compName As String = Nothing)
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Add Component")
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
Dim basePoint1 As Point3d = New Point3d(0.0, 0.0, 0.0)
Dim orientation1 As Matrix3x3
orientation1.Xx = 1.0
orientation1.Xy = 0.0
orientation1.Xz = 0.0
orientation1.Yx = 0.0
orientation1.Yy = 1.0
orientation1.Yz = 0.0
orientation1.Zx = 0.0
orientation1.Zy = 0.0
orientation1.Zz = 1.0
Dim component1 As Assemblies.Component
component1 = parentPart.ComponentAssembly.AddComponent(compPath, refSet, compName, basePoint1, orientation1, 1, partLoadStatus1, True)
lw.WriteLine(parentPart.FullPath & " -> component added: " & compPath)
End Sub
#End Region
End Function
End Module
#Region "NXTree and Node classes"
'class adapted from: http://www.java2s.com/Code/VB/Generics/Defineandus...
Public Class NXTree(Of T)
Private m_Root As NXTreeNode(Of T) = Nothing
'<Description("The tree's root node."), Category("Data")> _
Public Property Root() As NXTreeNode(Of T)
Get
Return m_Root
End Get
Set(ByVal value As NXTreeNode(Of T))
m_Root = value
End Set
End Property
Public Sub Clear()
m_Root = Nothing
End Sub
Public Function MakeRoot(ByVal node_item As T) As NXTreeNode(Of T)
m_Root = New NXTreeNode(Of T)(node_item)
Return m_Root
End Function
Public Overrides Function ToString() As String
Return m_Root.ToString()
End Function
End Class
Public Class NXTreeNode(Of T)
Public NodeObject As T
Public Children As New List(Of NXTreeNode(Of T))
Public Quantity As Integer = 1
Public Sub New(ByVal node_object As T)
NodeObject = node_object
End Sub
Public Function AddChild(ByVal node_item As T) As NXTreeNode(Of T)
Dim child_node As New NXTreeNode(Of T)(node_item)
For Each tempNode As NXTreeNode(Of T) In Children
If tempNode.NodeObject.Equals(node_item) Then
tempNode.Quantity += 1
Return tempNode
End If
Next
Children.Add(child_node)
Return child_node
End Function
Public Shadows Function ToString(Optional ByVal indent As Integer = 0) As String
Dim txt As String
txt = New String(" "c, indent) & NodeObject.ToString & " x" & Quantity.ToString & vbCrLf
For Each child As NXTreeNode(Of T) In Children
txt &= child.ToString(indent + 2)
Next child
Return txt
End Function
End Class
#End Region
Please do the needful
RE: Assembly Creation using a Text File
Hello Sdinesh134,
This highlighted portion of example code needs to be changed to specify directory path on you computer that has write access.
HTH,
Joe
CODE --> VB
Hey Joe
Thanks for your effort.
The folder is in Desktop ,so there are no issues with that.The issue is with the Template file.That i had changed now .
But i get my part file getting created rather as an assembly.
1
.2
.3
.4
The error i get now is
NXopen .NX Exception:Attempt to add a componnet to a part flaggedas apiece part
at NXopen.Assemblies.ComponentAssembly.AddComponnet(String part toAdd,string referenceset Name,String component Name,Ponit3d basepoint,Matrix3x3xorientation,Int32layer,PartLoadStatus,Boolean uomAsNgc)
at Module3.AddComponent(Part parentPart,String comp Path,String refSet,String compName) in
C:\Users\dinessu\Appdata\local\Temp\NXJournel95040\journel0.vb.line 352
at Module3.Process Tree(NXTreeNode1 BOMTree,List1_ListFinished) in C:\Users\dinessu\Appdata\local\Temp\NXJournel95040\journel0.vb.line 126
at Module3.Main() in C:\Users\dinessu\Appdata\local\Temp\NXJournel95040\journel0.vb.line 55
Please suggest.
Hello Sdinesh134,
That sounds like the template part has been saved with "Enforce Piece Part" set to ON.
Either use a different template part or edit and save the template part file after using "File->Utilities->Enforce Piece Part...", Uncheck "Enforce as Piece Part"
Hope this helps,
Joe
Hello Joe
Please find the attached image.
Enforced Piece Part is greyed in my case .I am unable to nither turn it on nor turn it off.
They are my default settings.We have certain requirements to use the same template.
Please suggest.
There is no file attached...
Ignoring the journal code for a moment, using interactive commands: can you create a new file based on the template and add components to it? Or do you get a similar message about it being marked as a piece part?
www.nxjournaling.com
Hello Sdinesh134,
In this particular case the corporate customer specific add-ons are intentionally making this NX menu option unavailable.
Please accept my apology but I cannot in good conscience offer additional assistance to contravene corporate standards.
You may want to consider contacting someone in the IT/DC, CAD Systemgestaltung department.
HTH,
Joe
