CSA B51 Interpretation
I have a question regarding Hydropneumatic Expansion Tank vessels. Paragraph 7.4.3 states: "Hydropneumatic tanks shall have a minimum design pressure of 690 kpa and meet the requirements Section VIII, Division 1 of the ASME Code. A hydropneumatic tank with a maximum diameter of 610 mm, a total volume of 450 L or less and a temperature of 65C or less shall not be subject to the requirements of this Standard."
So does this mean if a hydropneumatic tank is 610mm in diameter, less than 450L volume and a temperature less than 65C it does not have to meet the requirements of ASME Section VIII, Div. 1 (no overpressure protection required, no Manufacturer's Data Report, etc.?
RE: CSA B51 Interpretation
General Blr. CA,USA
Thank you for the reply. But if the equipment is exempt from the CSA B51 Standard, why would a CRN be required? I'm not getting good replies from the provincial AI.
