hand cranking a Tiger tank
Hand cranking a Tiger tank using the inertial starter.
Scroll about 2/3rds down the page for the actual video.
B.E.
B.E.
You are judged not by what you know, but by what you can do.
RE: hand cranking a Tiger tank
Here is an airplane started with an inertial starter.
https://www.youtube.com/watch?v=3zXkVQnVmuo
A lot of the early Boeing Stearman trainers were also fitted with this same style of inertial starter.
B.E.
Although of a vastly different era, an M60 with the Continental V12 produced 1200 HP.
You learn something every day.
Mike McCann, PE, SE (WA)
B.E.
I once saw a metal plaque on an old MG set in a circa 1900 powerhouse that stated it was not to be used in any Aircraft. That must not have been a German product.
Cheers
Greg Locock
Fifty-four tons at thirty MPH was a lot of fun, though.
old field guy
Of course, the gasoline engine got only a third the fuel economy of the diesel - i.i MPG for the diesel, 0.5 MPG for the gasoline version. Many of us in colder climes lamented the loss ot the gasoline as it was superior fuel for tent heaters.
Another step backward from the M48 to the M60 was doing away with 'Little Joe', an auxiliary gasoline-powered generator. Little Joe meant you didn't have to keep the main engine idling while you were sitting in one place, something we found ourselves doing quite often. If you messed around and depleted your batteries to the point that the main engine wouldn't start, quite often yuo could electrically start Little Joe, and if you couldn't start it electrically, it had a pull-rope starter just like a lawn mower.
Probably more than you wanted to know, but every now and then I like to re-live my misspent youth.
old field guy
But yeah, getting a multi-ton piece of metal up a steep hill with 100hp is... interesting (especially when someone is lobbing brass shells at you)
Dan - Owner
http://www.Hi-TecDesigns.com
msquared, actually it was the Americans and Brits that tried to make anything fly.
Many WWII US tanks used Aircraft derived engines in at least some of their variants, the Brits used them in most of their Cruisers - initially a liberty V12 then later a Merlin derivative. Due to differences in Octane of fuel used (i.e. lower compression), omission of super/turbo charging etc. the tank versions were often significantly lower out put than the most sooped up aircraft engines.
Off the top of my head I'm not sure any WWII tank had more than 750 ish hp. Some of the early war tanks had less than most cars have today - not even in triple digits.
They also used AC aircraft engines for powering most of their motor torpedo/Gun boats (PT boats).
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
old field guy
Switches off, position , Contact , What do you mean that wasn't it?
B.E.
Absolutely! I meant that the gentlemen had not put the mag switch in the proper position for operation. Two minutes of grinding on that handle, the prop turns over, and you hear an expletive fromt he cockpuit, the "Sorry... One more try."
old field guy
A.
Growing up in the UK one of the local farmers had Field Marshal tractor . This was started with a 12bore blank cartridge.
They generally left the thing running , but if they had to start it in the town you would always get a circle of small kids myself included who just had to watch. There is a better film on the back of the video I posted.
B.E.
A.
This is getting a long way from tanks.
B.E.
et voila back at tanks, you're welcome berkshire
Dan - Owner
Think you're right about AVPIN on the Hunter. Still makes a lot of sudden noise. I'd forgotten all about that ghastly stuff (and will now try to do so again)!
A.
There are stories that circulate in aviation circles, of people who used AVPIN as a cleaner with undesired results.
B.E.
Dan - Owner
Anyway got the impression that some Avons (early?) were cartridge started, but I'm sure as can be Lightening was Avpin.
The Lightning never seemed to get out very much - and when it did, there was always somebody out to upstage it. I remember the BBC filming the opening titles to a TV series by pointing a camera backwards down the spine of Lightning as it did a few zoom climbs off the main runway. An hour or so after they'd finished (run out of fuel/hydraulic oil), somebody got a Harrier out and spent twenty minutes or so flying the same profile - just at about a tenth of the speed.
A.
