How do I make Family Tables on Catia like Pro/E?
I have a question about design tables.
I have used Pro/E family tables to create multiple part from a single model. I'n Pro/E when you open the Parent Part you can select which instance to open.
How can I do this in Catia?
I've tried working with Design Tables but don't know how to use them like family tables on Pro/E so I can choose which instance I want
Do I have to add a part name parameter in Knowledge advisor and link it to design table?
Thank you,
Michael
Thank you,
Michael
RE: How do I make Family Tables on Catia like Pro/E?
this functionality (like famiky or configuration) not available yet.
wishes
hmk
www.catiatips.de
What you can do is create a Catalog.
Start the Catalog Editor, pick Add Part Family, then browse to the part that contains the Design Table.
You might want to check the Help Docs for further instructions.
Hope that points you in the right place.
Check out
Part Family creation in CATIA V5 R8
Thread560-40647
The response from
tjs4689 (Aerospace)
On Jan 14, 2003
gives a detailed description of Catalog creation
Michael
