Problem with model change and remesh in abaqus.
Dear,
I am trying to carry out the following steps in my model:
- Model.inp: remove one area of the piece with model change.
- Inport the model.odb with file/import/part deformable stage, choose steps.
- Remesh the model.
- Generate new model and remove other area with model change.
But I have the following problem. When I import the model.odb, in the part does not consider the model change I have done.As it can be seen in the picture I have attached(inport.) Despite opening the odb file I can see that the model change has been done.
How can I solve the problem? I can use the model change with remesh operation?
Do you have any suggestion?
Thanks for your help.
Ane
