Epoxy vs Acrylic Sealant for Concrete
My company has some older concrete secondary containment structures for oily water tanks located in the Northwest. The concrete has shrinkage cracks that have been expanded do to freeze thaw cycles. The cracks are still relative thin but we want to take corrective actions before they get worse. My recommendation was to dry the surfaces, apply a trowel grade epoxy grout to any cracks or bug holes, and coat the surfaces with an epoxy sealant to prevent water from entering the cracks. I have since been asked if acrylic sealant would be appropriate. I have never used acrylic sealant for this type of application. My initial research found that acrylic may work but that epoxy is much more durable. Want to see what kind of results the group has has with either product for this type of application.
RE: Epoxy vs Acrylic Sealant for Concrete
Dik
