Text spacing and ratio set in drawing vba catia
I can not figure it out how to set Spacing or Ratio in drawing text from VBA.
I know how to adjust eg. Text.SetFontName 0,0, "Arial" or Text.SetFontSize 0,0, 2, but how to adjust spacing?
Some ideas?
Thank you
RE: Text spacing and ratio set in drawing vba catia
I couldn't find the Character options exposed to automation.
Some of the other options can be accessed via the TextProperties object, but I couldn't find Spacing or Ratio. You would probably need CAA. Maybe someone else can confirm.
CODE --> catvba
Dim drawingText1 As DrawingText
Set drawingText1 = drawingTexts1.GetItem("Text.1")
Dim drawingTextProperties1 As DrawingTextProperties
Set drawingTextProperties1 = drawingText1.TextProperties
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
Does anyone knows how to take the spacing between two rows of text? or this is not exposed for programming?
