Missing element definitions revisited - CAE 6.14.1 bug?
OK yes I know the following error is common but bare with me..
The Error:
***ERROR: 981589 elements have missing property definitions. The elements have
been identified in element set ErrElemMissingSection.
All material assignments & sections have been made correctly.
How do I know this?
Because I ran an initial model with the load going through a RF point & it ran no problem with no errors.
All I have changed is the position of the loading point. That's it! No other change to model at all!!
When the *.inp file is written out, after moving the RF point, none of the section definitions are written to the input deck!
The only work around I have found so far is to rebuild from scratch.
Anyone else seen this kind of error before?
