Basic excel parametric sweep
Hello colleagues
I have a range of cells with input data. For each of it i want to put corresponding value into a calculations sheet and store the result into new range - how to do that with VBA ?
thanx and kind regards
RE: Basic excel parametric sweep
Sub CopyData()
Range("TargetRangeName").Value = Range("SourceRangeName").Value
End Sub
If you want to do something more complicated, can you provide more details.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
You haven't helped yourself with your statements. Can you upload your workbook or at least post an example that illustrates your problem?
Skip,
Just traded in my OLD subtlety...
for a NUance!
TTFN (ta ta for now)
I agree that the Data Table feature is probably the easiest option, but another way to go if you are happy with VBA is to create a User Defined Function which is entered as an array formula. That can then return an array of any required size.
As Skip said, an example workbook showing what you have so far would be helpful.
Doug Jenkins
