B31.3 Occasional Load Factor For Elevated Temperature Fluid Service
I am trying to calculate what occasional load factor that I need to use for elevated temperature fluid service. B31.3 para 302.3.6 states that the occasional load factor as an alternative to using 1.33 times the basic allowable stress may be taken as the "strength reduction factor" multiplied by 90% of the yield strength at temperature. What is the "strength reduction factor" and where can I find it. The only other places that I find "strength reduction factor" mentioned in the code is for the weld strength reduction factor. Please help. I am dealing with 1550F pipe and want to make sure that I am correctly calculating the factor.
RE: B31.3 Occasional Load Factor For Elevated Temperature Fluid Service
