Pump Maximum Flow Rate
Hi, I would like to ask how to determine the maximum flow rate for Gorman-Rupp Pumps. Its not in the nameplate. Should I base it on the performance curve and take the reading on the maximum side of the operating range. Please advise. Thank you.
RE: Pump Maximum Flow Rate
What is the application that you are having? Are you able to share rated head, flow, speed? If you can post a pump curve it would also help.
If it's not there then I would use the end point on the curve.
Often max flow is limited by motor rating, but even within the numbers listed there might be high vibration or high NPSH to contend with.
Or just call them and ask them.....
Please find the attached performance curve and specification sheet as references.
You'll need also to keep an eye on the NPSH and power values deriving from your chosen flow. Your motor and suction conditions need to be suitable for them.
Max flow through pump seems to be 80 to 90 m3/HR depending on speed.
Under thus type of use and depending on discharge and suction head, the pump will / could run out along the curve until it cavitates - now it might hunt up and down the curve or conditions might just coincide with the curve and the unit might run OK. At the other end of the curve as the sump may empty, the pump will be operating at very low flow well up the curve and the pump will probably lose prime and snore until the sump level inreases and the sequence recommences.
If you would like to explain fully what you are doing / expect when you are likely to get better advice.
Edited:; the comment re. Operating up the curve is only applicable if you are pumping against a high static discharge head.
Asking the question on this forum with such little background information is akin to the game of twenty questions.
