Telomer Resistance
Telomer Resistance
Telomer Resistance
Good afternoon eng-tip users,
I have a quick question about coatings. Currently we have a steel fixture uswed for holding sheet metal as it gets sprayed with telomer and then baked in the furnance. This fixture becomes heavily coated with Telomer and requires quite abrqasaive cleaning, usually sand blasting which erodes the fixture and requires it to be sent out to an external vendor, my question is, is there a coating that could be applied to the fixture that would increase its "telomer resistantance" requiring less frequent cleaning and less abrasive (done on site)
Cheers!
RE: Telomer Resistance
Kapton tape?
tin foil?
Do you meal Al foil?
You can also buy light gauge stainless steel foil.
