NX11 Product template studio?
Hi all,
Please tell in NX11 Product template studio avilabele or not?
Kiran Kale
RE: NX11 Product template studio?
Yes...Should be directly available from the NX interface...no more separate application.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
That's correct.
The external Java UI was retired in NX 11, and Product Template Studio is available directly within the main NX UI now.
We hope you love it!
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Product Engineering Software
Siemens Product Lifecycle Management Software Inc.
(Phoenix, Arizona)
Hi All,
I don't know if this is the correct place to post it but I have another question about the PTS in NX11.
I was making a PTS using linked faces and linked datum coordinate systems as input. In the PTS I was able to select the linked faces (in the feature tab), however the linked CSYS was not found in the PTS environment. At the moment I circumvented this problem by using NX 10 first. So, I start making the PTS in NX 10 and include the linked CSYS. Thereafter, I open the PTS in NX 11 and the CSYS is still linked in the PTS. However, when I want to link another CSYS in NX 11 directly this is still not possible. Is this a bug or do I overlook something?
Additionally I face a problem with linked sketches, when I re-use my PTS I get the internal error : memory access violation. I thought this was strange because if I just copy paste the PTS part and manually relink the sketch then it is working just fine.
Somebody here having similar problems or even better some thoughts about solving it :)
Please create a new topic for this.
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
