Grounding transformer
Is there a reason why grounding transformer are wye-delta? If I had some auxiliary loads that I wanted to power from the secondary, could I make it wye (gnd) - wye (gnd)?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Grounding transformer
Marmite
Marmite
Three distribution transformers rated for line to line voltage may be used for the wye:delta grounding bank.
Bill
"Why not the best?"
Jimmy Carter
