Contact resistance of thermal grease between rigid metal plates
Hi Folks,
I'm looking for contact thermal resistance (degC/Watt) of thermal grease of a specified thickness between two rigid metal plates with variable pressure (from fasteners).
Also, how about the dry contact resistance (degC/Watt) between the same plates with variable plate flatness and plate surface finish?
Thanks in advance!
Bruce
Thanks in advance!
Bruce
Tunalover
RE: Contact resistance of thermal grease between rigid metal plates
http://www.lytron.com/Tools-and-Technical-Referenc...
https://www.electronics-cooling.com/1997/05/calcul...
https://www.dowcorning.com/content/publishedlit/11...
www.nrel.gov/transportation/pdfs/42972.pdf
TTFN (ta ta for now)
As usual you come up with the right stuff!
Tunalover
