High Purity CO2 Gas
High Purity CO2 Gas
High Purity CO2 Gas
Flow Rate : 500~ 1000kg/hr (total Gas Flow)
Composition
CO2 :99.993 vol.%
O2 : 25ppm
N2 : 35ppm
H2O : 1.5ppm
others : 8.5ppm (as unknown)
Question:
We will intend to increase CO2 Contents up to 99.999%
First We want to remove N2 and O2 from CO2 Gas
comment Device or method ? please
RE: High Purity CO2 Gas
At this purity level, and given that CO2 is polar while O2/N2 are non polar, would suggest mole sieves - talk to UOP or Rhone Poulenc or Linde. They will also want to know pressures and temps for feed and exit streams.
thank you georgeverghese for your reply.
I discussed this with UOP. But they answered Mole sieves is not the solution.
I am thinking How about Membrane...anyway thank you again..
What were the reasons UOP said this isnt possible? Also talk to either one of the other vendors and see if they can give you a second opinion. Also chat with the people at BASF.
Membranes cannot help at these purity levels - they work okay for coarser separations.
Low temp extractive distillation (say with chilled propane or chilled butane) may be possible, but operating expenses will go through the roof.
