Does Precast Frame Structure(Precast columns, beams & HCS) requires expansion Joint?
Hi
I have a full precast frame structure with plan size 100 x 50 m . Does this building require expansion joints? 20 mm gap between every beam and column at corbel is not sufficient?
RE: Does Precast Frame Structure(Precast columns, beams & HCS) requires expansion Joint?
Dik
