Clamping force required
Lets say you have a piece of 1/4 plate bolted to the end of a 3 x 3 x .25 HSS. A force of 900 pounds is applied at the end of the plate 19" away from the center of the bolt. What would be the clamping force required by the bolt to resist the plate moving? Picture attached.
So the moment acting on the pivot would be 900*19 = 17100 in-lbs, which I'm assuming is what the resisting frictional torque has to be equal to or greater than. I can't really find an equation related to this problem. The static coefficient of friction between steel on steel, clamping force, and maybe contact area all are variables? Any input would be appreciated, thanks.
RE: Clamping force required
If your design must resist a turning moment as shown, it sucks. Use a four bolt pattern.
You can make a crude estimate of your force through the Newtonian physics you learned either in high school, or by second year college at the latest. For anything more accurate, I would suggest building something and testing it.
JHG
If you're worried about the bolts/washers not keeping it stationary under duress, bolting in addition to dowels may be necessary.
Can you bend the plate in a 90 toward the beam and then a 90 down so the bend binds on the beam?
I used to count sand. Now I don't count at all.
badpoor these days...The problem with sloppy work is that the supply FAR EXCEEDS the demand
Obviously, when a load is placed on the end of the fork arm a force couple is created on the two horizontal HSS members. If the fork arms are extended all the way to the ends, then you get more deflection/twisting. Yes, I know a multiple bolt pattern would more effectively resist the tendency of the beams to "twist." Any small step to reduce cost is important, though, so if it was theoretically possible to stop any movement with a single bolt, then that removes extra cost when fabricating this. Or maybe not, maybe the clamping force would necessitate a very large bolt. Hence why I'm posing the question.
Now, maybe I'm overthinking this but the clamping force needed would be a function of the resisting moment (needs to be equal to or greater than applied moment), the coefficient of static friction between steel, and the distance away this friction force acts from the pivot point, correct? So:
Clamping force = Resisting moment/µ*d
Clamping force = 17100 in-lbs/(0.5*1.375) = 24,872 pounds.
This is assuming a static coefficient of friction of about 0.5, and a radial distance to the tube wall of about 1.375 from the center of the pivot. Seems quite large to me, but maybe this is too simplistic? Does the contact area between the rotating 1/4 plate and the tube wall have an affect?
On some cars, they peen faying surfaces to prevent slip.
A very wise man decades ago told me about designing equipment,"Five years from now they won't know if it was a few dollars over budget or two weeks late. But they will by God know if it works." Those words have served me well.
A short chunk of smaller rectangular or a square of 3/8 inch plate with nipped corners could be welded to the arm, engaging the tube inside walls.
Similar to this -
https://encrypted-tbn0.gstatic.com/images?q=tbn:AN...
The feature that the bolt screws into is missing.
Your line of thinking isn't far off, though. Consider the above advice regarding welded/bent stops or dowels and the costs associated with these, then the cost of more bolts, drilling more holes, and so on...
900 pounds acting at 19 inches isn't a tremendous force to resist; you'll be able to come up with something clever and economical. Report back to the thread and show us when you do!
I have to agree with others that relying on a single bolt is not good design and I would suggest a minimum of two bolts because then you are not relying solely on friction to hold the plate in position.
Now regarding the question of the clamping force, I calculate that it would need to be a minimum of 3600lbf to resist the 900lbf you intend to impose on it. This figure however is purely theoretical because I have assumed that the coefficient of friction is 0.25 and area of the clamped parts is independent of friction (in practice it isn't).Now if the actual coefficient of friction was only 0.2 then the clamping then the force would need to increase to 4500lbf as a minimum to prevent movement of the stop plate. From my example above you can see a variation in friction coefficient significantly alters the minimum clamping force and I wonder how you are going to control that friction coefficient consistently so that a known clamping force guarantee's the connection won't fail? In addition to this you will have to ensure a consistent bolt load in the fixing which will probably mean pre-tensioning the bolt as torque cannot be relied on.
If you use two bolts or more then the friction problem completely goes away because now for the plate to move the bolts have to fail and that is much easier to calculate or predict than relying on friction. Now you mention saving money, so consider the cost of:- buying bolt tensioning gear, spending hours testing the clamping joint in conjunction with variable friction and then compare that with the cost of drilling another hole and adding a bolt.
All I used was the theory of sliding friction , F= mu * R where F = 900lbf and mu= 0.2
Two bolts means you can use two barely strong-enough bolts that can keep the plate in place, and not have to worry about the surface conditions, and the only indicator that the bolts are backing out can be the fact that the plate is getting wobbly.
I don't follow the same logic you do in identifying the single bolt as 'cheaper'.
desertfox, your calculation assumes that the plate only has to resist 900 lbf of lateral movement, but this is a torque we are talking about, so I don't believe a simple F = mu*R is appropriate for this example.
Yeah. Regardless of whether or not you want to factor surface area into your analysis, the location (radially) of that frictional force will be critical to know.
For a given load, a simple thrust bearing washer arrangement will take more torque to turn as the washer grows in diameter.
Yes I forgot the moment arm however how are you going to ensure that 24,872lbf in your calculation is going to occur at the edge of the box section, when a bolt is tightened its pressure from under the head spreads out in a 60 degree cone (30 degrees either side of vertical).
My guess is if you draw the cone from under the bolt head you won't even reach the edge of the box section and even if you do, you're back to controlling the bolt preload accurately, so you're calculation is really also inappropriate if you think about it.
To me it's a no brainier putting at least two fixings in the joint, far cheaper, more reliable and a damn sight safer.
Mike
For your effective clamped radius, I would use the radius of the head of your screw. There some interesting Belleville washers in the McMaster Carr catalogue that could increase your clamping radius to that of the washer. Half the width of your arm is very optimistic.
JHG
The bolt threads into a piece of angle-iron welded to the inside of the HSS, so I suppose the resisting frictional torque will be more-so acting on that surface rather than the tube walls, because as you said the pressure distribution from a bolt will not spread out nearly that far to make enough difference.
So the question remains, when two flat surfaces are contacting, how do you calculate the clamping force needed to induce a resisting frictional torque on one surface to counteract the applied moment on the other?
Torque = Fbolt x mu x r.
For a rectangular tube I'd play it safe and assume r was about 1/2 the tube width. Also I think mu = .5 is a bit optimistic. I'd use mu = .1.
Torque = Fbolt*mu*r
Fbolt = Torque/mu*r
Fbolt = 17100 in-lbs / (0.1*.140) = 1,221,429 pounds...
You don’t really seem interested in good design info. and advice, and you have been given plenty of it above, if you’d just read carefully and think a little. Maybe it can be summed up in saying that it is not wise engineering to count on friction to take a significant load or impulse. You be the judge. You’re not really hearing what’s being said, you haven’t explained the details of your problem and design very well, and we certainly can’t see it from here. So do it your way. Make one, and tighten the bolt until you get enough bolt tension to hold your load in whatever way is satisfactory for your needs. Call this the min. torque req’rd., and put some factor of safety on that and call it good. Then start worrying about some of the advice you’ve been given above. One failure, may well, cost many times what a dozen of these things done with good design would cost.
1/4" bolt no less, I'd expect you'll break it before you get the clamp force you need.
Mike
You are correct even with two bolts the joint can slip however it won't slip if the are tightened correctly. Look at this website below and see the calculation for bolts resisting shear generated by a torque.
With a single bolt the end stop can rotate 360?degrees if it comes loose but with two bolts it can only move till the clearence is taken up between the bolt and hole.
http://www.roymech.co.uk/Useful_Tables/Screws/Bolt...
Is a single bolt a bad design to retain this assembly as a rigid frame because it relies upon friction? I think that's universally agreed upon, and obviously a multi-bolt pattern is much more effective at handling eccentric loading, however:
1) I'm much more interested in the physics behind the problem I stated.
2) The single bolt idea is not mine. Again, the value of design critique is not lost on me, but its not really the kind of information I'm looking for.
Mike
Could you work the preload equation in reverse ? If you preload the bolt with an applied torque, isn't it reasonable to say that the bolt can resist that torque; ie tighten the bolt with the torque expected (obviously factoring this by 1.5 would give you some reassurance inservice) ? Use T = Pd/5.
wotcha think?
There is nothing wrong with relying on friction to hold something in place. There is something wrong with relying on friction that requires a 1/4" bolt to exert 1.2M pounds.
JHG
using T = Pd/5, 17100*5/0.25 = 342000 lbs ... equally unreasonable ... suggests the design is unreasonable (by my calcs a 1" bolt is down, good for 80,000 lbs ULT)
We were not concerned with the torsional stiffness of the tube, what the OP was asking was if he fastens a flat plate to the end of a tube with a single bolt and then applies torque to the flat plate what clamping force does he need to generate between the flat plate and the tube end to prevent the flat plate rotating.
3000 lbs X 0.1 for friction = 300 lbs sliding force resistance.
17,100 in-lbs of torque would require 17,100/300 = 57 " effective radius where the friction/contact must be applied.
I'd cut 3 pieces of 2.5 " long angle instead of 1.
Then I'd Weld one angle down inside the tube 2 inches or so(to provide plenty of fastener length for elongation and reliable preload retention when things shift/embed a little bit, with a cage nut or ??? to provide threads for the bolt.
Finally, I'd Weld two of the angles to the face of the lever, positioned to engage the square tube snugly, but inset to miss the fillet welds securing the angles to the lever.
The OP is applying a couple of 900lb×19" radius. He wants to resist this with a single, 1/4" bolt. We need to know what radius the bolt acts at. The radius of the clearance hole is a good, conservative estimate. The stiffness of the tube is not important. The stiffness of that plate/arm is what matters here.
Here is another way to visualize the problem. I install the bolt and nut with a wrench. How long is the wrench handle? How much force can I exert on the end of the wrench handle? Could these numbers be less than 19" and 900lb?
JHG
