Butterfly Valve, Series DS
hello
what is Series DS in butterfly valve? Dose any other series for this valve?
thank you
thank you
RE: Butterfly Valve, Series DS
Probably abbreviation for Data Sheet.
Images of Series DS Butterfly Valves:
https://www.google.com/search?q=Series+DS+Butterfl...
And here:
www.alnajim.com/newsletter/pro-pdf/Orton_DS.pdf
Sometimes its possible to do all the right things and still get bad results
I found more as follow:
