Weaving tapes: Problems in connecting nodes and multiple contacts
Hi guys,
I hope you guys can help me in this matter. I want to analyze a woven configuration made of weaving tapes under a constant load. The tapes are bonded to each other but I'm afraid the nodes are not connected between the tapes, yielding inaccurate results. There are also a number of contact areas due to the weaving configurations. How can I connect the nodes between the tapes?
For easier understanding, a picture of the weaving model is attached with this post.
Could anyone advise me on how to go about this? One advice I got was to just make a homogenous layer instead of modeling the weaving profile.
Thank you.
img http://files.engineering.com/getfile.aspx?folder=4...]
Thank you.
RE: Weaving tapes: Problems in connecting nodes and multiple contacts
You show the tape making neat right angle bends when it weaves between the cross tapes. To get the response of a woven tape, you want to include orthotropic material properties, and the direction will change when the tape bends. You need to figure out how to account for that in your model.
I dont think the homogeneous layer will work because at any depth in the section, you will have tape running in each direction at different points in the layer.
Rick Fischer
Principal Engineer
Argonne National Laboratory
