Amount of component x condensed along with water vapour during reaction
Hello all,
Need your help please.
I want to calculate amount of component x condensed along with water vapour during reaction. The reactor batch is 10 tonne.
The reaction takes place at 180 degC at which component x is removed and condensed.
Vapour pressure of the component x at 180 degC = 0.001
Vapour pressure of water at 180 degC = 10 bar
Molecular wt of component x = 300 g/mol
RE: Amount of component x condensed along with water vapour during reaction
You should condense 0.001 cc of component X vapor for every 10 cc of water vapor. Now convert cc's to mass units for each component.
Using simple rules such as Raoults Law to compute the water condensed would be appropriate only if the reaction mix is ideal - for non ideal mixes, there would be significant deviations.
A condenser will significantly sub-cool the condensate so this is not an equilibrium problem.
Thanks all,
I don't think Raoult's law would be applicable here.
Please let me know if my calculation below is correct
Here, X is mass % of component x
((X⁄300))/((((100-X))⁄18) )=0.001/10
((X⁄300))/((((100-X))⁄18) )= 0.0001
x/300=(0.0001*(100-X))/18
18X=0.03*(100-X)
18X=3-0.03X
X=1.66%
I don't think above calculations is correct though. Any input would be highly appreciated.
