Problem with Cable system
Hello, friends. I have some sort of trouble working in machinery module. I can't wrap a cable between two pulleys if that pulley was extra rotated around any axis. But the same pulley created with marker works (Adams can wrap a cable between them but it does it in the wrong way- cable doesn't skirt a pulley but is located at one side). Why can't I wrap a cable between two pylleys created by different ways and why doesn't the created cable skirt around the pullley?
Thank you!
RE: Problem with Cable system
Thank you for your answer but I have already seen the HELP so it didn't help so much... There is no information about creating pulleys by different ways. Only how to create and use.
Not responding for 3 days...
