CATIA vb.net error inserting PowerCopy
More one time I need Help.
I'm developing something to insert a powercopy in a part, using vb.net. and this worked before. But today this error is happening:
I thought that it was the references of the project. Then I removed it, and inserted it again, but some error.
I have no idea......
Tiago Figueiredo
Tooling Engineer
RE: CATIA vb.net error inserting PowerCopy
Save the project, build the project and run the exe file directly, not from VS. Before this, kill/close all CATIA sessions and open again CATIA.
Check if you will get errors.
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
there is an error as well.
Tiago Figueiredo
Tooling Engineer
do you have any idea?
Tiago Figueiredo
Tooling Engineer
Fernando
Tiago Figueiredo
Tooling Engineer
If it still happens, please let me know, I would like to let you try a new app included in my TST application, a Clean_Junk_Memory (you can find similar applications on web). Unfortunately, I wasn't able to try it on my laptop, it didn't happened to me recently this kind of error.
Fernando
Like I said this worked in another computer...
I decided to make a copy of the powercopy file, and it worked... I really hate computers. It was just like copy and past the file, delete the old one and it worked... Before this I tried to insert the powercopy with the powercopy command (without macro), and it worked. Nothing of this was giving me any idea that the problem was the powercopy file, because it was working well.
I have passed all morning and part of the afternoon, cleaning up files (ccleanner), removing old software, restarting computer every time this error occurred, unistalling and installing visual studio, and then with a simple copy past the file it worked. I really hate computers....
Tiago Figueiredo
Tooling Engineer
Tiago Figueiredo
Tooling Engineer
Fernando
it's happening again, and I don't now why. I did the same that I did last time, and no sucess.
I hope you have some ideas to help me.
Tiago Figueiredo
Tooling Engineer
https://www.youtube.com/watch?v=TfW1LesWP9o
And for now is working. I changed target CPU to X86. I hope with this the problem became solved. Let's see the coming days.
Tiago Figueiredo
Tooling Engineer
Tiago Figueiredo
Tooling Engineer
https://www.youtube.com/watch?v=buaQaw-zbWo
Tiago Figueiredo
Tooling Engineer
Fernando
Tiago Figueiredo
Tooling Engineer
