Integrity of riveted overhead crane bridge.
We have a 60 Ton electric overhead crane in our facility that was manufactured in 1892.  The bridge is riveted construction and has a 60'-0" span.  The manufacturer has advised that we remove it from service, without any physical inspection, I assume simply because of its age and the potential liability.  We realize that metal cold works becoming brittle and has a fatique limit as well.  Are there any non-distructive tests we can perform on the steel &/or rivets to determine their integrity?
