Flanges of Steel Girders not Orientated in Direction of the Grain
I designed some steel girders... The way the fabrication shop "nested" the flanges on the steel plate, was so that it was skewed and not orientated with the grain of the plate. The flanges were skewed approximately 14 deg from horizontal - direction of the grain. My boss is currently out on PTO so I am just trying to do some research in the meantime to determine if this will be a problem. The girder will be loaded in bending so one flange will be in tension and the other in compression. I wanted to place this in the materials forum but noticed how little activity there is on it. Any thoughts in the meantime are appreciated.
Edit: Material is high grade steel - API 2H GR50
RE: Flanges of Steel Girders not Orientated in Direction of the Grain
I watched an AISC webinar a year ago by Duane Miller -- talking about welding of course, but as part of that, he went into the different properties of steel relative to the rolling axis.
For transverse and longitudinal strength, steel yield and ultimate capacity was essentially identical. (Based on a Barsom and Korvink study)
(Also, this comes up commonly in curved steel girder flanges -- and I've never heard of any special consideration there).
https://www.aisc.org/globalassets/continuing-educa...
I see you added the steel grade. I have never worked with that specification, but at first glance it doesn't seem too exotic.
How did you know the grain orientation was skewed?
Ron: I didn't, they haven't cut yet and received an RFI. They skewed it to be able to fit more pieces and thus order less material. Completely understandable. It will be under dynamic loading but it has a very short life-span (several months) so would not be concerned from a fatigue point of view.
