Re: Macro to create an Isometric View on a CATDrawing
thread560-401763: Macro to create an Isometric View on a CATDrawing
Hi, I figured I would join since this forum has helped me numerous times before.
In the referenced thread above, the OP asks how to create an Isometric View in a CatDrawing and set it to Raster mode. I had trouble with his formula to find vector1 to generate the Iso so I am posting what I found to work, and how to render the view as raster.
Be pre-warned, I am not a computer programmer by trade and my last VBScript class was 10+ years ago in high school. So my code may not be the most efficient or cleanest. Any tips are welcome. :)
Also, my script is .catvbs so my declarations do not have "as string", etc.
First, we need to modify some Catia Settings so the default view generation mode is Raster
Let's get the vectors for the current 3D view, "Up" and "Sight"
Now we need to find the cross product vector which gives us the missing leg of the trihedron
We can now generate the Iso view
Finally, we revert the changed Catia Settings
CODE --> CATVBS
Dim settingControllers1
Set settingControllers1 = CATIA.SettingControllers
Dim settingRepository1
Set settingRepository1 = settingControllers1.Item("DraftingOptions")
Dim CurrentSetting1,CurrentSetting2,CurrentSetting3,CurrentSetting4
CurrentSetting1 = settingRepository1.GetAttr("CATDrwLODPrintMod") 'capture current setting for Drafting>View>raster print quality
CurrentSetting2 = settingRepository1.GetAttr("CATDrwRasterMod") 'capture current setting for Drafting>View>raster mode
CurrentSetting3 = settingRepository1.GetAttr("DrwGenerationModeVal") 'capture current setting for Drafting>View>view generation mode
CurrentSetting4 = settingRepository1.GetAttr("CATDrwLODVisuMod") 'capture current setting for Drafting>View>raster print quality
settingRepository1.PutAttr "DrwGenerationModeVal", 2 'change to raster mode
settingRepository1.PutAttr "CATDrwRasterMod", 2 'change to shading with edges
settingRepository1.PutAttr "CATDrwLODPrintMod", 1 'normal quality
settingRepository1.PutAttr "CATDrwLODVisuMod", 1 'normal quality Let's get the vectors for the current 3D view, "Up" and "Sight"
CODE --> CATVBS
viewer3D1.viewpoint3D.GetUpDirection Up viewer3D1.viewpoint3D.GetSightDirection Sight
CODE --> CATVBS
Dim Sight0,Sight1,Sight2 Sight0 = -1*( (Up(1))*(Sight(2)) - (Up(2))*(Sight(1)) ) 'WARNING - this has worked in 4 tests, but further verification is needed to make sure the -1* is always needed Sight1 = (Up(0))*(Sight(2)) - (Up(2))*(Sight(0)) Sight2 = -1*( (Up(0))*(Sight(1)) - (Up(1))*(Sight(0)) ) 'WARNING - this has worked in 4 tests, but further verification is needed to make sure the -1* is always needed
CODE --> CATVBS
drawingViewGenerativeBehavior1.DefineIsometricView Sight0,Sight1,Sight2,Up(0),Up(1),Up(2)
CODE --> CATVBS
settingRepository1.PutAttr "CATDrwLODVisuMod", CurrentSetting4 settingRepository1.PutAttr "DrwGenerationModeVal", CurrentSetting3 settingRepository1.PutAttr "CATDrwRasterMod", CurrentSetting2 settingRepository1.PutAttr "CATDrwLODPrintMod", CurrentSetting1
