hole_table_dimension_cover_in_sheet
Hello@ Experts,
Happy new year,
i have query in NX 11
i have part in nx as image,
i give dimension via hole table, but in hole table the cells & columns are getting out of sheet,
my question is how to cover or fit column & raw of hole table in sheet, how to do partition of column
i attached image of it
if anybody idea for it, please share it
Best regards
Thomas Roman
NX-11
Machine Designer
Happy new year,
Best regards
Thomas Roman
NX-11
Machine Designer
RE: hole_table_dimension_cover_in_sheet
Hoover over the table and when the whole one set of table is highlighted/selected RMB and select "Settings"
Then change value in: Settings-> Common -> Section -> Maximum Height (=less than sheet height)
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V10.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
